Digital I/O
How to connect and measure from an NPN inductive sensor on NI-9422
I'm new to data aquisition and have just recieved a C-Rio with a 9422-module. I've tried to use both sinking and sourcing inductive sensors but I don't get any response when I connect the sinking one (3-wire). I'm not sure if I have connected it the right way though. How should the leads be connected (+, earth and "signal") and is there any settings I should do on the 9422 to make it sourcing?
Thanks for any help
Calle
(4,508 Views)
Please look at page 10 of the NI 9422 datasheet as it shows typical connection of a sinking sensor. It seems to indicate you need an external voltage source of between 11-60V, the exact voltage will depend on the specification of your inductive sensor. Page 7 has the wiring diagram of the 9422 for your reference.
I hope this helps!
(4,419 Views)
