Digital I/O
How to export square wave using HSDIO
Hi there,
I have successfully exported the sample clock and the reference clock out and viewed it on my oscilloscope. What i saw was a continuous SINE wave. Will it be possible to get square wave out from the refernce clock or sample clock?
The reason why I need to do that is because I am trying to generate a 10Mhz square wave. I had tried using generation with scripting to generate the square wave but the highest it can generate is 1.6Mhz, anything above that, system will give an error.
Therefore, I managed to achieved the 10Mhz wave but it's in SINE wave. So will it be possible to get it in square wave?
Thanks for the help in advance.
(3,397 Views)
Hi Keith -
The clock outputs of the HSDIO devices are square waves.  How are you instrumenting the clocks?
Keith Shapiro
National Instruments R&D
(3,374 Views)
