Digital I/O
How to get a USB-6008 to function on a XP laptop?
I cannot get a new usb-6008 to be recognixed by Measurement & Automation explorer or any example codes on my XP laptop. The 6008 works fine on a XP desktop. Also on the laptop it does show as working properly in Device Manager. What do you suggest? - J Griggs
(3,396 Views)
Hi J Griggs,
I would recommend you try to the troubleshooting steps in the following KBs:
Using a USB-6008 / 6009 / 6501 in MAX, and Switching Firmware Between NI-DAQmx and NI-DAQmx Base
Why Do I Get a Measurement & Automation Explorer (MAX) Database Connection Error? (Try step 4 only)
Also, what version of the NI-DAQmx driver do you have installed?
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,374 Views)
