Digital I/O
How to increase timing period in Digital Pattern Editor?
Is there a way to increase the Period in the Timing Sheet of Digital Pattern Editor over the 4E-05 maximum?
I need to run a digital test at low speed, but I do not find a good way to do it using the Digital Pattern Editor. Previously I used the Digital Waveform Editor and there was a tool, Resample Waveform, which allowed to expand a waveform. That could be a way to get around the problem. But I also do not find that possibility in the Digital Pattern Editor.
(3,001 Views)
Hi FJR0,
There should not be any limits on how slow you can run a digital test. Have you tried looking at the Specification.specs tab and specifying a lower frequency for the period? Also under the timing tab you can specify a formula as to the frequency you want to output your data at as a function of the period. For an example of how to implement this, please navigate to Help>>Getting Started Example and have a look at the example called SPI Example.
I hope this helps.
(2,935 Views)
Looking at the spec sheet for the PXIe-6570, it seems that this is some hardware limit. The vector period range is specified as 10 ns to 40 us, so it can not run slower than 25 kHz. What I am doing at the moment is to use a repeat(25) Opcode for each vector in the pattern to reduce the speed to 1 kHz. But it does not look like the ideal solution.
(2,931 Views)
You are correct, for your application the characteristics of the PXIe-6570 are the limiting factor. A possible solution would be to use different hardware that has the characteristics you require.
(2,922 Views)
An alternative is to oversample by using repeat opcode in each vector.
Example, max vector period if 40us but you want a period of 120us, better to use NR drive format, use repeat(3) on each vector. This way you can achieve the 120us slow vector.
Caution! - RL, RH, SBC don't work well will oversampling and it will still be at the specified vector period.
Santhosh
Soliton Technologies
(2,891 Views)
