Digital I/O
How to reset PXI-6509 under program control
At the beginning of my TestStand sequence I would like to reset the Modules in my PXI chassis to the default state. I can reset the NI-4060 and PXI-6025E by inputting the device numbers into the Device Reset.vi. I don't seem to be able to do the same with the PXI-6509. Any suggestions?
(4,017 Views)
Hi Steve,
Do you get an error when trying to reset your PXI-6509 with that VI? I would like to know how you know that the device has not been reset.
Thanks!
Laura
(4,004 Views)
Hi Laura,
Thanks for helping. I have tried various combinations with both the device and device string inputs to the Device Reset.vi. Using the device input results in the error: "-10005 badDeviceError The device is invalid". I've tried various string inputs (just guessing really) and I get the error: "-10001 syntaxError An error was detected in the input string; the arrangement or ordering of the characters in the string is not consistent with the expected ordering".
So far, it appears that I can only reset the two modules listed in Measurement and Automation Explorer/Traditional NI-DAQ Devices (PXI-4060=Device 4, PXI-6025E=Device 5). The PXI-6509 is only listed under Measurement and Automation Explorer/NI-DAQmx Devices (PXI-6509:"PXI1Slot2").
Steve
(4,002 Views)
Hi Steve,
Ok, I think I see the trouble. The PXI-6509 is a DAQmx device only, so you must use the VI "DAQmx Reset Device" which is in the DAQmx - Data Acquisition >> DAQmx device configuration palette.
Laura
(3,998 Views)
Thanks for the help but I think I have solved the problem
I found another reset vi that appears to work for the modules that are listed in Measurement and Automation Explorer as NI-DAQmx Devices. The vi is: DAQmx Reset Device.vi. After placing the vi on the block diagram I selected create constant on the device input and got a dropdown menu that listed the PXI-6025E and the PXI-6509 as options. Select either one and that device will be reset when the vi runs.
I tested this vi by toggling some inputs with the 6509 then running the DAQmx Reset Device.vi. All of the inputs returned to the default state.
Steve
(3,997 Views)
Laura,
Looks like I was replying while you were.
Thanks again,
Steve
(3,996 Views)
