01-04-2007 09:47 AM
01-04-2007
11:06 AM
- last edited on
05-19-2025
01:29 PM
by
Content Cleaner
That's a traditional DAQ function and you need to use the newer DAQmx driver. You should have gotten DAQmx with the device and with your LabVIEW 7.1 distribution. You can download the latest from here.
01-04-2007 11:22 AM
Hi Dennis.
I got the software with the DAQ, I installed, then reebot the PC, and I still getting the same error message. Do I need to confugure the board? (don't think so) I have sinking and sourcing ports on the 6518,
I install LabVIEW 7.1 and the software I got with the card is 8.20 but it will still support 7.1
I had long time using labVIEW and several boards, I know this a traditional board should work as other boards,
Regards.
Reynaldo Lima V.
01-04-2007
12:15 PM
- last edited on
05-19-2025
01:29 PM
by
Content Cleaner
You will get this error forever if you keep using Read From Digital Port. As I said before, that function interfaces to the traditional DAQ driver and the PCI-6518 is only supported by DAQmx - see here. This is a fairly new board and is not "traditional". The latest version of traditional DAQ is 7.4.1 so the 8.2 version of the driver you got has to be DAQmx. Open the example finder and look at the the DAQmx examples.
01-04-2007 01:31 PM
Thanks Dennis...
I will give a try,,, I saw the DAQmx functions.
Regards.
