Digital I/O
How to use SPI Script usb-8451?
I need to send 11 bits of data (vs 8 bits) over the SPI of the USB-8451. I believe that the Advanced API should do this but I do not know how to set-up the script. Code in MS C/C++ would be nice or a basic program flow would do. I could not find and C/C++ examples, only LabView examples. Any guidance would be appreciated.
(4,404 Views)
Have you looked at the NI-845x Software User Manual?
Pages 7-3 to 7-6 describe the Advanced API and include a programming example using the scriptingfunctions of the Advanced API.
Peter Flores
(4,392 Views)
I was mistaken about the 11 bits it is 11 data+5 address=16 bits. Now the issue I have is with the 'delay' between the 2 8-bit transfers. I thought that I would be able to removed this delay but I guess it is overhead required to load the SPI shift register. If only NI had a product that was 32 bits deed and routines to 'chop' it up into bytes, words, etc... Both the BASIC and ADVANCED APIs have the delay embedded in them, any suggestions?
(4,384 Views)
