Digital I/O
How to use the PCI-DIO-32HS counter
I have to create a SPI, I'd like to use counter, but the card doesn't answer, so Labview bug. Do you if there is programmable/configurable counter on this Card?
(3,206 Views)
The PCI-DIO-32HS does have a counter onboard. However the counter is only used for generating an internal clock in order to do pattern generation. You cannot program this counter in LabVIEW. If you need a counter, I would look at using an M Series Board, or a 660X board.
Justin T.
(3,206 Views)
