02-22-2006 12:29 AM
02-22-2006
05:22 PM
- last edited on
11-26-2025
06:05 PM
by
Content Cleaner
I strongly recommend that you upgrade to a newer version of LabVIEW. This will enable you to use the DAQmx driver, which will make programming your application significantly easier.
With that being said, the best way to control an LED is to use a digital output program. There are some great examples in the LabVIEW Example Finder for this. They will be under Help >> Find Examples >> Hardware Input and Output >> Traditional DAQ.
Hal L.
