Digital I/O
I NEED THE DIO advanced VIs ( Port Config, and Read/Write Port VI) AND I DON'T KNOW WHERE ARE THEY
Hi.
Somebody can tell me what i need to install for have the DIO advanced VIs - Port Config, and Read/Write Port VI.
(3,957 Views)
Those are functions in the traditional DAQ driver. You should also have copy on your LabVIEW device drivers CD. Whether you can use them will depend on the DAQ board you have. Newer boards such as the M series require a different driver (DAQmx). There's also a question of whether you should be using them. DAQmx is the new and improved driver for NI DAQ boards and is the only driver being updated. What board are you using and what version of LabVIEW?
(3,954 Views)
Hi Dennis ... thank's for help me.
The problem is that i was running a proyect but i had to format the PC and when i reinstall the software and dirvers those VIs are missing. I'm using Labview 7.1 and install DAQmx 8.0.0f5 and mi divice is the PCI-6527 ...
Do you think that i need to install a before version of DAQ dirvers?
(3,950 Views)
As I said, DAQmx and traditional DAQ are two completely different drivers. You installed DAQmx. You need to install traditional DAQ. I don't remember which version that came with 7.1 but the version I linked to should work if you want to download it.
(3,947 Views)
OK I'll install .... thank you very much.
(3,943 Views)
