Digital I/O
I/O Acquisition with NI 6533: bandwith problems
Dear All,
I am doing a digital I/O application with a NI6533 card. The data I am trying to read comes from a digital source that gives 2 bits (lines) at ~17 MHz. I have seen that the most fast sustained acquisition with 6533 is the BURST mode. For this reason, I am trying to use this mode. I have connected ACK, and REC to 5V all the time. Like this the card will always try to read from the device which is constantly giving data at 17 MHz. I use the internal clock of the card.
The PC I use is a PIV at 1.8 MHz with an ASUS motherboard and 1Gb of RAM memory. In the PCI slots there's "only" a network card, a video card, and the NI6533 card. The operating system is Win98.
The software first version loads all data
into memory (later I will deal with the hard drive). In principle, this card is supposed to use DMA channels, and it seems that they are configured. However, I am experiencing bandwith problems. During the acquisition the following error is generated:
Error -10845 occurred at Digital Buffer Read.
NI-DAQ LV: Because of system and/or bus-bandwidth limitations, the driver could not read data from the device fast enough to keep up with the device throughput; the onboard device memory reported an overflow error.
Anybody has any clue or experienced something similar before?
Then I have a second problem, even if I have 1Gb memory I cannot load 500 Mb into memory (and I checked
it is free). It seems that the maximum ammount of memory I am using is limited.
Anybody experienced this, as well?
Thank you in advance, and sorry for the long email,
Cheers,
Ernest Mendoza
(3,235 Views)
The 6533 card does not have onboard memory like the 6534. Even though the onboard clock has a frequency of 20MHz, the data input is governed by the system you are using -- PCI bandwidth limits the data tansfer rate to the PC memory. Check the following related articles: Keywords Search: stream to disk 653x. The 6534 card has 64 MBytes of onboard memory (32 MBytes per group) -- this allows it to sustain higher input rates, however, I doubt it will sustain a 17MHz continuous acquisition (to the PC memory).
RamziH.
Message Edited by Molly K on 02-19-2005 12:09 AM
(3,236 Views)
