Digital I/O
I am using the 6533 high speed digital I/O card with the first port (P
ort 0) configured for buffered output. Intermittently the following error appears, "An exception 0E has occurred at address in VxD NIPALK (01) + address. This was called from address in VxD NIPALK (01) + address. It may be possible to continue normally.I am using LABVIEW 6.I and NI-Daq Driver version 6.8.1. Are there any known problems with this driver?
(4,059 Views)
ort 0) configured for buffered output. Intermittently the following error appears, "An exception 0E has occurred at address in VxD NIPALK (01) + address. This was called from address in VxD NIPALK (01) + address. It may be possible to continue normally.I've never seen this error before, but there is a newer version of the NI-DAQ driver (6.9) available for download from the NI website at:
http://digital.ni.com/softlib.nsf/current
(4,059 Views)
