Digital I/O
I can't get writeDigPort(OSX) to run from the shell.
I've compiled the NIDAQmxBase DIO examples for MacOSX
and I'm using a USB-6501. They run fine when I click on
their icons but when I try to run them from the command line
I get the error
tcsh: writeDigPort: Command not found.
However if I do an ls the files are there.
Any ideas what's going on here. Thanks much,
Doug Taylor
(3,356 Views)
Hi Doug,
From what I understand, you need to use ./ to run a program when you are in its directory.
Hope this helps,
Laura
(3,350 Views)
Thanks Laura,
That worked. I gues I have to get over my Amiga and Dos days :). Best,
Doug
(3,342 Views)
