Digital I/O
I connected the jumper in PXI 6508 card to LOW state, after that also the power up state of the card is not changed to LOW. What is the problem?
I am using PXI 6508 for acquiring Digital Signals in my application. The Default power up state of the card while shipped is HIGH. Then I changed the Jumper W1 on the card to LOW and restart PXI. After this also the power up state of the card is HIGH. I used DMM to measure the voltage across the Port 9 and DGND. (pin numbers 98 and 100). I tried this for 3 ports and the result is same.
Let me know how to solve this issue.
M.Valliappan.
(3,896 Views)
Hi valliappan,
Just to verify the jumper position, please see the diagram enclosed in the following KnowledgeBase:
Setting the PXI-6508 / PCI-6503 Start-Up State Via Jumper W1
Please try using the Measurement & Automation Explorer Test Panel to verify the power-up state. If you manually pull low the lines low, what kind of readings do you get in MAX?
Lesley Y.
(3,879 Views)
M.Valliappan,
Please take a look at this KnowledgeBase:
http://digital.ni.com/public.nsf/allkb/5EB377C6A0C5C83F86256FBE00730E62
It will explain the behavior you are seeing. Please let us know if the information in the KB will not help you solve your application needs.
Thank you,
Allen
(3,875 Views)
Hai Lesley,
I connected the Jumper as per the picture and Measured the Power Up state. At that time alll the ports are reading HIGH.
If I give a LOW signal manually to a particular port, MAX reads it as LOW signal.
M.Valliappan.
(3,863 Views)
Hai Allen,
Thanks for your web link to the document. I will go through it and try to solve the issue.
M.Valliappan.
(3,862 Views)
