Digital I/O
I don't know how to use 9402 in FPGA of Labview
     Now,I am using 9402 in FPGA modle of 9144 .But I want to know how to set a output channel of 9402.I want to let it output a digital singal and then let other input channel of 9402  accept it!I know how to set input and output model of 9402.
    Can you give me a example for this idea?
(3,736 Views)
You should see the IO in your project once you added the module to the FPGA.  From there, just drag your IO to your block diagram and wire them up.  It is pretty straight-forward.
(3,733 Views)
