Digital I/O
I need a LV driver for an Opto22 PCI-AC5 DIO card
I am having a difficult time finding a LV driver for an Opto22 PCI-AC5 DIO card.   They support C++ and VB but there is little to no support for LabVIEW. Please let me know if you have written or come accross a driver for this board. I'll take anything right now as long as it gets me going in the right direction even a rough driver will do.
Thank you
(3,643 Views)
Could you explain a little more about how you communicate between your PC and the Opto22 PCI-AC5?
My guess is that it probably has various drivers and that you could call into the the dlls and make the various calls necessary to operate the board by having LabVIEW call into it.  You might also contact Opto22 and see if they would develop a LabVIEW driver that could better access the board.  Finally, you could contact an Alliance member and see about them developing a driver for you.
Best of luck,
(3,620 Views)
Thank you for your response. As it is I've finally gotten lab to call the .DELL correctly. The call Library function took some research but it did do the job quite nicely.
(3,621 Views)
