Digital I/O
I need to replace a PCI-DIO-32HS with a command compatible new DIO card. What is my best choice?
I am running some old Windows XP systems and need to replace the current PCI-DIO-32HS card.  I don't have access to the program code that I am using, so I need a command compatible replacement.  Any idea which current board would best meet my needs?  Or am I out to lunch?
(4,414 Views)
Assuming the old program is using DAQmx, you should be able to just use the PCIe-6536B.  You will need to do some configuring inside of MAX to make sure all of the settings match.
(4,412 Views)
