Digital I/O
I need to use 5V TTL signal for my board.
I need to generate 5V TTL signal for my board.
Can anyone suggest which NI card I can use to generate this signal.
I guess NI-7868R or 7854R can generate up to 3.3V TTL signal, please confirm this.
(2,113 Views)
You can always add a logic level translator.
Santhosh
Soliton Technologies
(2,108 Views)
What other details are associated with this signal?  Is it a "static" signal?  Is it a clock?  If so, what frequency?  Is it a communication signal?  If so, what data rate?
(2,095 Views)
What EXACTLY do you mean by "5V TTL"?
Do you mean +5V is logic high?
Or do you really mean 1966 vintage 74 series TTL?  "A TTL input signal is defined as "low" when between 0 V and 0.8 V with respect to the ground terminal, and "high" when between 2 V and VCC (5 V)" (Wikipedia).
(1,900 Views)
