Digital I/O
I2C bus monitoring
Hello all,
I have a RIO evaluation kit and I use 2 of its digital I/O to control an I2C bus as a master and now I have many I2C slave devices which i want to get a data from each one by writting the address of a slave device and draw it as graph !!
anyone can help me please ..
may be at first how to detect the start condition where the serial data (SDA DI/O) and serial clock (SCL other DI/O) are both high then the SDA goes low after it the SCL goes to low ... and after the start condition the address of the slave come and data and so on...
thanks in advance
Mustafa
(7,920 Views)
Hallo Mustafa,
Verify the digital IO selected for the I2C bus is what is needed.
This could help you  I2C Implementation in LabVIEW FPGA
For instructions on implementing the code see "How to Get Started with this Code.pdf" in the documentation folder in the attached zip file
(7,841 Views)
Here are some specific resources for SPI and I2C communication on LabVIEW FPGA:
SPI and I2C Driver API - National Instruments
https://www.ni.com/en/support/downloads/tools-network/download.spi-and-i2c-driver-api.html
Reference example-Simple I2C Communication to DAC IC using LabVIEW FPGA
https://forums.ni.com/t5/Example-Code/Simple-I2C-Communication-to-DAC-IC-using-LabVIEW-FPGA/ta-p/399...
Hope this helps!
(7,840 Views)
Thank you for your kind reply sir hsm78.. I couldn't apply the I2C core which is in the link you mentioned..
actually I build a simple VIs inorder to save the digital input from the SDA and SCL into an arrays  but it doesn't gives good result can you see the code and if any one has an idea on how to make monitoring i mean to give an address then check when this address come in the i2c bus then read the data after it.
thanks in advance
(7,511 Views)
