Digital I/O
In debug mode, can't set breakpoints on some valid lines of code.
In debug mode, can't set breakpoints on valid lines of C code. Also, at random skips lines of code when I try to single step thru code.
(3,549 Views)
Dear Lasani
Thank you for choosing National Instruments!
Would it be possible for you to give some more details regarding this issue? Are you using DAQmx C calls and getting this behavior? Can you post a small snippet of code or give example segments? Also, what kind of hardware are you using to do data acquisition?
Thanks and Regards
Shekhar S
(3,549 Views)
I have resolved the problem. Appartently, when I recompiled my code, the object file was not being updated??? I had to delete the old version (obj file) and then re-compile.
(3,549 Views)
