I need to interface from a NI 6533 DAQ card to 2 grayhill 70RCK16 switch cards. The 6533 card has a 68 pin connector and the 2 grayhill's have a 50 pin edge connector. They normally have a 50 pin ribbon cable and easily interfaces with the NI PC-DIO-24 card. Without some sort of adapter, each of the 32 channels needed will have to be hardwired from the ribbon cable. Is there any adapter that will do this?
