Digital I/O
Interface
Boa tarde,
Estou a ter problemas com um interface. O problema está explicado no ficheiro em anexo. Algum esclarecimento relativamente a este assunto, contacte-me via e-mail (daniel carvalho@contar.pt] ou via telefónico (218313100).
Estou com alguma urgência neste assunto, pois não estou a conseguir resolver este meu problema.
Obrigado,
Daniel Carvalho
(4,602 Views)
Hi M. Carvalho,
I'm sorry but we don't really understand what you want to really do... Make a connector on your PCB? Do you want the wiring connection?
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
(4,579 Views)
Hello M. David,
No. I just want a connector that can be attached in a structure, and is one of the sides (Sheet 68 Pin Male), and the other is (68-Pin Flat Male).
Do you understand?
Sincerely,
Daniel Carvalho
(4,570 Views)
Ok I understood.
Her you have all the connector we have to make this:
https://www.ni.com/en/search.html?pg=1&ps=10&q=777600-01
If you don't find the right connector, it is that we don't make this one.
Sincerely
(4,568 Views)
