Digital I/O
Inverted Outputs using DAQMX
I have found out how to read the inverted properties.  If you set the inverted to true it reads back a false.  Which is counter intuitive.
Message 11 of 13
(2,927 Views)
I have been able to read the inverted lines but it is counter intuitive.  If you set a channel TRUE it reads back a FALSE.
Message 12 of 13
(2,925 Views)
What would you expect for inverted inputs?  They are useful when dealing with Negative Logic (which a lot of safety critical situations seem to really like).
Message 13 of 13
(2,921 Views)
