Digital I/O
Is it possible to connect Multiple DUT's in parallel to a single NI 6552 HSDIO for characterization?
I would like to know if I could connect two parallel DUT's to one NI 6552 HSDIO to obtain characterization for both DUT's simultaneously?
Also, I would like to know what the specifications are for CLK OUT if such a configuration is to be done.
Thanks for your help!
(5,288 Views)
How many pins do your DUTs need to use? What kind of responce are you expecting? If you are looking to test a communication protocol, like I2C, these cards are not really built for these kinds of tests. Are you expecting the DUTs to respond at the same time?
Noah | Applications Engineer | National Instruments
(5,259 Views)
