Digital I/O
Is the PCI-6236 a good choice?
I have to measure an analog signal (4-20 mA) and a digital signal which come from two different sensors. The acquisition of the first signal (analog) should be done at the rising & falling edges of the digital signal. And at the same time, I have to count how many rising/falling edges occured during the experience (10 seconds). I would like to choose the PCI-6236 acquisition card but I'm not sure of my choice... Can somebody help me choosing the right device?
Thank you!
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,703 Views)
In my opinion, a USB 6008, or USB 6009 should be quite appropriate for your requirements, and shurely less expensive...
Don't hesitate to directly contact NI, this way you'll be able to talk to a very qualified person that will guide you through the different steps in acquireing an appropriate acquisition device regarding to your application.
Hope this helps,
Regards
Richard Keromen
(3,684 Views)
Thank you very much for your answer!
(3,680 Views)
