Digital I/O
Is the number of lines limited when using change detection and PCI-6509 card
Hi!
I'm making C++ application which should read data at least from 56 lines. For now, I use SIMULATED PCI-6509 device.
Device will send back data up to 32 lines, but after that it send only zero values. It doesn't matter which lines I use, only how many. Does anybody know if the problem is in simulation program, in my code or other?
Test enviroment:
Vista 64 SP1, Visual studio 2008, NI-DAQmx 8.9
For simplicity I tested this problem with NI example code and got same result:
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; elseint main(void)
int32 error=0;
TaskHandle taskHandle=0;
uInt8 data[224];
char errBuff[2048]={'\0'};
int32 numRead;
int32 bytesPerSamp;
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateDIChan(taskHandle,"Dev1/line0:55","",DAQmx_Val_ChanPerLine));DAQmxErrChk (DAQmxCfgChangeDetectionTiming(taskHandle,
"Dev1/line0:55","Dev1/line0:55",DAQmx_Val_ContSamps,4));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
printf(
"Continuously reading. Press Ctrl+C to interrupt\n");
while( 1 )
// DAQmx Read Code
DAQmxErrChk (DAQmxReadDigitalLines (taskHandle,4,10.0,DAQmx_Val_GroupByScanNumber,data,224,&numRead,&bytesPerSamp,NULL));
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);printf(
"End of program, press Enter key to quit\n");
getchar();
return 0;
Message 1 of 1
(3,681 Views)
