Digital I/O
Issue with +5v pins on USB-6501
Hello, I am using a USB-6501 (advertised as new) in a simple Digital I/O application.  It is recognized by the PC when plugged in, and I can control it with a LV 32 bit UI with no problem.  My issue is the +5v pins on the unit are not steady, they appear to go between 0 and +5v, appearing to be in sync with the status LED.  My experience is the +5v should be steady on unless it is put in Suspend mode.  Is the intermittent +5v normal, and is there a way to stop it?  Or do I have a defective 6501?  Thanks.
(448 Views)
+5V pin is directly off the USB's 5V supply and tend to fluctuate based on the load which is dependent on the 6501's functionality, as the 6501 circuit and +5V pin share the same rail over the USB cable.
As observed from the snippet, the +5V rail can be between 4V and 5.25V
Santhosh
Soliton Technologies
(413 Views)
Accepted by topic author MKBNIS
@santo_13 wrote:
+5V pin is directly off the USB's 5V supply...
One of many reasons I highly recommend using an externally powered USB hub when dealing with DAQ devices. I have had many issues with USB hubs on motherboards, especially laptops, not being able to supply the current despite the USB specification.
(392 Views)
Thanks for the replies; two things though.  The +5v is fluctuating from 0v to 5v, with none of the I\O's connected to anything, just the USB cable to a USB3 compatible port on a Dell Precision.  However I will try a powered hub, as I have run into issues with unpowered hubs before.  I also have a USB-6009, and it does not seem to have this problem with its +5v out.
(375 Views)
I tried a test today with a powered hub (supply is rated to over 4 amps), and still have the problem with the USB-6501 (+5v pin to GND at the connector outputs pins 31 and 32 fluctuate from 0 to +5v, synced to the flashing of its connection LED).  With the same setup I swapped a USB-6009, and measured the voltage at pins 31 and 32 as a steady 5.18V.
To make the problem a bit more confusing, I purchased two of the USB-6501's at the same time, and both have the same +5v behavior.  Ugh...
(357 Views)
How much current are you loading on +5V pin?
Santhosh
(330 Views)
Hello Santhosh, thanks for the reply.  There is nothing connected to the 6501 other than the USB cable to the USB hub.  All 32 IO pins are connected.
But after a bit more testing, I found one of the two 6501's has a steady +5v on its power pins, so I believe it is safe to assume that the original 6501 has some sort of defect.  It seems strange that its 0-5v power pin transition is in sync with the flashing LED.  But I plan to return the 6501 in question for a replacement.
Thanks to all of you for the replies!
(322 Views)
