Digital I/O
Looking for a simple BNC output card
Hello
To control a electro stimulator I need my computer to send 5V signals through a BNC connection. In general what I'm looking for is the least expensive way to control a BNC ouput using Labview. I was thinking of a PCI card that has two BNC outputs, but if that's not  possible I could connect a BNC connector block through the NA 6031E card that's already in the computer. This card is currently used to control Delsys EMG acquisition hardware. I'd like to be able to keep this device connected. There's a Delsys 64 channel expansion module connected to the card with two unused slots.
Thanx in advance
Remco
(3,681 Views)
You should be able to use any of our M series DAQ cards with a BNC-2110 to provide a complete shielded BNC solution. You can also use a PCI-4461 to have direct connectivity from analog output through BNC.
If you are just looking to provide +5V through BNC and want a cheaper (unsheilded) solution you could just purchase a USB-6008 and use a BNC to bare wire cable to connect to the screw terminals.
For a more complete look at our data acquisition line please refer to this page.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,677 Views)
