Digital I/O
Mating Connector for NI 182762-01 (Test Cable Assembly, Ribbon Cable, R100M-50F-50F Cable, 1 m) IDC side
I cannot find the corresponding mating connector for the 5NI 182762-01 (Test Cable Assembly, Ribbon Cable, R100M-50F-50F Cable, 1 m) on the IDC side, Which mating connector is recommended by National Instruments. it should be at 90 Positioned.
(643 Views)
According to Selecting an Output Accessory for Your Instrument, R1005050 connection ribbon cable is to be used with the CB-50 or CB-50LP connector block
https://tmesystems.net/
(616 Views)
Thank you for your reply. Actually, this cable will be mounted on PCB, can please send out the datasheet of this cable or dimension(pitch), so that we know the exact pitch on the shrouded side of connector. or any suggested part that is through hole and vertical mounted.
Thanks and regards
(590 Views)
