Digital I/O
Max Update Rate of NI 9375 Digital Outputs
I have a NI 9375 module in a cDAQ-9174 connected to a Windows 8 PC running LabView 2012 with service Pack 1.
No matter what I do, I cannot get the digital outputs of the NI 9375 to update faster than 48 per second.
I need to generate a 40 Hz square wave.
Am I missing some configuration settings?  What can I do to double the update rate?
James
(5,994 Views)
If you use hardware timing, you can update the 9375 outputs at up to 2kHz.
If you are not using hardware timing, I would guess that you have create channel followed by write in a loop.  This causes the task to be recommitted after every write.  If this is your setup, call DAQmx Start before your write.
(5,987 Views)
