Digital I/O
Merge I/O lines?
Is there any way to merge I/O lines?
Here is my issue.  I have 40 thermistors, i want to be able to toggle them individually to either read air speed or temperature.  For this i have to run them with 2 seperate scanned write blocks.  One block will use the PID to vary the current, the other block has a non-changing current of 100uA.
Is there any way to create and manipulate an array of I/O lines?
(4,614 Views)
You can create a DAQmx task with multiple channels (lines) in it.  You can then write to the task using a 1D array of booleans.
(4,597 Views)
i'll give that a try thanks
(4,585 Views)
