Digital I/O
Multiple digital Outputs are not working while programming using internal clock
*Facing problems while using NIDAQ 6259 (m series) with ANSI C in windows 2000*
I am attaching an ANSI C program, which outputs two digital signals based on certain conditions.
I have configured the digital output channels using
DAQmxErrChk
(DAQmxCreateDOChan(taskHandle1,"Dev1/port0/line0:1","",DAQmx_Val_ChanPerLine));
and oututting the values in a loop using onboard clock using
DAQmxErrChk
(DAQmxWriteDigitalU32(taskHandle1,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
My problem is this:
While checking the outputs at the line 0 and line 1 of port 0, I am
getting the outputs only on line 0, while line 1 does not show the output.
I tried to configure it also as "Dev1/port0/line1:2". In this case, it is
not showing any of the outputs. The change of ports also does not seem to
be working.
Please guide me asap.
Thank you.
(3,304 Views)
shukla,
Please try running the attached code.  It should set lines 0 and 1 of Dev1/port0 low and then high in an alternating pattern.  I have tested this code and it worked on my PCI-6251, so it should work for you.  Try to compare the basic structure of your code to this simple example.  This may help you to find what is going wrong.
(3,294 Views)
