Digital I/O
Mysterious Error Message: -200170
I m new to this forum and to National Instruments programming, so if this is not posted to the best board, please direct me to the best one.
I am writing a program in C++ on a Macintosh, driving a USB-6008 to control my heating and cooling system. My code, included below, is rather closely derived from WriteDigPort.cpp included with the examples. The forst problem is, it is unreliable at opening the channel. With a probability of about 1/3, the call to DAQmxBaseCreateDOChan gives an error of -200170, "Physical channel specified does not exist on this device". The erratic nature of this error, on consecutive runs a few minutes apart without unplugging or rebooting anything, is really confusing. Should i be looking for warranty service on my device?
I am using NI-DAQmx_Base_2.1.0 under MacOS 10.4.10.
// Task parameters
int32       error = 0;
TaskHandle  taskHandle = 0;
char        errBuff[2048];
// Channel parameters
char        chan[] = "Dev1/port0";
// Write parameters
uInt32      w_data [1];
int32       written;
uInt32    data = 0;
void BlinkLED() {
int i;
   // Create Digital Output (DO) Task and Channel
   DAQmxErrChk (DAQmxBaseCreateTask ("", &taskHandle));
   do {
        int error;
        bool bad;
        error = DAQmxBaseCreateDOChan(taskHandle,chan,"",DAQmx_Val_ChanForAllLines);
        if (bad=DAQmxFailed (error)){
            DAQmxBaseGetExtendedErrorInfo (errBuff, 2048);
            if (error)
                printf ("DAQmxBase Error %d: %s\n", error, errBuff);
        usleep(500000);
    } while bad;
      for (i=0; i<2; i++) {
        w_data[0] = data;
        printf("Data to write: 0x%X\n", w_data[0]);
        DAQmxErrChk (DAQmxBaseWriteDigitalU32(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,w_data,&written,NULL));
        sleep(1);
        data = data ^ 0xff;
Error:
   if (DAQmxFailed (error))
   if (taskHandle != 0)
      DAQmxBaseStopTask (taskHandle);
      DAQmxBaseClearTask (taskHandle);
   if (error)
(3,261 Views)
Hi
Does your program work properly without throwing any errors the other 2/3 of the time?  If so, does anything change in the system when it gives the error of 200170?  When you run an example (like the DAQmxBaseCreateDOChan) do you see this error occur intermittently?  I see in your program that the channel specified is Dev1/port0.  Is Dev1 the correct device name?
I found an article that may help explain this issue so I would recommend to check it out.
Using a USB-6008 / 6009 / 6501 in MAX, and Switching Firmware Between NI-DAQmx and NI-DAQmx Base
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIRDCA4&l=en-US
Also, you do not necessarily need it but there is a newer DAQmx base driver available for download on our Website compatible with Mac OS X 10.4 (Tiger) on Intel or PowerPC (10.4.8 or later)
Jordan F
(3,242 Views)
