Digital I/O
NI 5761R AUX I/O Connector
In NI 5671R AUX I/O Connector is a normal D-Sub connector . Can I able to considered normal D-Sub 15 Pin Connector.
Vignesh M
(1,926 Views)
according to datasheet aux I/O is 68-pin male VHDCI connector.
(1,901 Views)
Sorry by mistake it was mentioned as NI 5671R.
Actually the correct model no is : NI 5761R AUX I/O Connector is a normal D-Sub connector . Can I able to considered normal D-Sub 15 Pin Connector.
I want to to know the gender the of the connector in card Side.
regards,
Vignesh M
(1,897 Views)
As per the datasheet, it is a 15 pin Micro D connector
Santhosh
Soliton Technologies
(1,838 Views)
Thank you for your reply.
Actually, I required the Micro d connector dimension or that connector mating part number.
regards
Vignesh M
(1,487 Views)
