Digital I/O
NI-6229 Digital Output Timing
I'm using two digital output lines to hook up to an SPI device.  I only need CS, CLK and MOSI, I do not need to hook up MISO.   The output is correct, however, I need to slow it down.  When I add the code below to slow it down, it does not work.  What am I doing wrong?
DAQmxCreateTask(
"", handle)
DAQmxCreateDOChan(*handle,
"/dev1/port0/line0,/dev1/port0/line1",/dev1/port0/line2, DAQmx_Val_ChanForAllLines);
// Code inserted to try and slow down timing
DAQmxCfgSampClkTiming(*handle, "/Dev1/Ctr0InternalOutput", 10000.0, DAQmx_Val_Rising, DAQmx_Val_ContSamps,1000);
DAQmxCreateCOPulseChanFreq(*handle, "Dev1/ctr0","",DAQmx_Val_Hz,DAQmx_Val_Low,0,10000.0,0.5);
DAQmxCfgImplicitTiming (*handle,DAQmx_Val_ContSamps, 1000);
// code fragment to burst out CS,CLK and MOSI
DAQmxWriteDigitalU32(handle, length, TRUE, 10.0, DAQmx_Val_GroupByScanNumber, (uInt32 *)buffer, &actual, NULL);
(3,562 Views)
Hi mwalter64,
It appears that your issue may be with the task you are using.  A task can only have one "type" of channel in it, so I believe you need to separate the DO and the Ctr into two separate tasks.  Other than this,  it looks like you are on the right track with using the Ctr0InternalOutput to control the speed of both tasks.  In order to keep things straight, I would also configure one task before the other.  What I mean by this is to go through the following steps in order:
CreateTask
    Create DO Chan
    Cfg Sample Clock
    Write DO                 \\Be sure autostart is F
Start task
CreateTask
    CfgImplicitTiming
    Start Task
    WriteCtrFreq
Stop both tasks
clear tasks
etc.
I hope this helps, if its not clear, post again and I will try to clarify.
Neal M.
NIC AE
www.ni.com/support
SR#: 1039621
Neal M.
Applications Engineering       National Instruments        www.ni.com/support
(3,532 Views)
