Hi Andreas,
There are a couple things I can suggest.
1) You can try upgrading to NI-DAQ 6.9.3 (ni.com/downloads)
2) It is either the 6534 hardware, NI-DAQ driver or your circuit, since option 1 takes care of the driver (I have it an it works well with pattern I/O and the 6534 we just need to worry about the other two. What I would do is generate pattern output out of 1 group and acquire the pattern input on the other group. Simply wire the two together so that the card is talking with itself. If you still see the bit errors when comparing the two buffers (should be exactly the same) then you know there must be something wrong with the card. There are NI examples that perform pattern I/O with the 6534 on the website. If the pattern seems to be fine, th
en it might be your circuit that you are connecting to. If that is the case, it might be difficult to verify your circuit.
It could also be the clock you are using for input. If there is a slight offset in the clock by the time the 6534 read the data, then it might read the previous bit or the next bit in its sequence. Take a look at all the bit errors and see if they are the same as the previous or next bit. If this is the case you will have to use a more stable clock source at the input or use a shorter wire for the clock.
It is unusual that the 6534 sees bit errors, and in the same relative location. I hope these suggestions help. Keep me posted on your testing.
Ron
