Digital I/O
NI 6552 Pattern generator incorrectly
Hello ,
   issue is facing while generating the toggle pulses on NI 6552 Line 0, the toggle sequence is being given up to 32 bit from pattern generator vi and observing only 18 pulses is coming out at line 0. i generated low byte pattern also but getting incorrect pattern. Please help me to correct program. I am using this card for generating clock and some known pattern along with.
The received output sequence is not matching with programmed pattern sequence .please look over the oscilloscope image and vi images.
I am attaching the Vi screen shots and measurement screen shot , please help me on that to correct it.
Message 1 of 1
(447 Views)
