Digital I/O
NI-6583 with PXIe-7976r error code -63150
I get the following error when executing my VI: Error -63150 occurred at niLvFpga_Open_PXIe-7965R.vi Possible reason(s): NI-RIO: (Hex 0xFFFF0952) An unspecified hardware failure has occurred. The operation could not be completed. The error occurred when I used the NI-6583 digital I/O module with PXIe-7976R to run the signal generation example. I changed the slot 7976R used and confirmed the connection between NI-6583, but the error still existed. The module worked fine days ago, but today it went bad. Is there any hardware problem with NI - 7976R ?
(2,329 Views)
Could you try other examples that do not use the 6583?  This will help us see if it is the FlexRIO or the FAM
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,293 Views)
