Digital I/O
NI 6585 clock to host
I have an NI 6585/PIXe-7691R is there was a way to get a clock signal to a host VI so that I can graph the clock along with some other IO in a digital waveform graph?
(5,134 Views)
Should be pretty easy to generate an equivalent waveform in the clock domain driven by the clock signal of interest.
Are you doing this for debugging purposes? If yes you may be interested in the sampling probe which allows you to observe signals over time while running in simulation mode.
(5,127 Views)
It is for debugging.  I am using labview 2012 is the probe function in that version?
(5,124 Views)
Looks like it was added in 2013.
(5,122 Views)
