Digital I/O
NI-845x I2C Run Script.vi got error -30742. I cannot write or read
Hi All, I am using Labview 8.5 and Ni-8451. I got the error coded -30742 during writing data into MCU. It works in Cypress IIC, but using Ni-8451 it won't work. Please help me with... Why I got this error? Any idea? Best Thanks. Jessie
(5,467 Views)
Hi Jessie,
When asking for assistance, remember to provide all data relevant to help you find a solution. Since the error code is undefined it would be a good idea to post your code and a screenshot of the error message. Also, it is important to post the question on the appropriate board. I2C related questions go to the Automotive and Embedded Networks board.
Double check the manual from the device you would like to read/write from because you may be having problems related to syntax.
Alejandro C. | National Instruments
(5,432 Views)
