Digital I/O
NI-9149 - Modbus TCP
I have a setup as follow,
Comm. Resource Name
Device name
Type
Physical Comm. Resource Name
Rack 1
192.168.1.1
Slot0
NI-9149
192.168.1.1
Slot1
NI-9208
192.168.1.1
Slot2
NI-9208
192.168.1.1
Slot3
NI-9208
192.168.1.1
Slot4
NI-9208
192.168.1.1
Slot5
NI-9208
192.168.1.1
Slot6
NI-9208
192.168.1.1
slot7
NI-9361
192.168.1.1
slot8
NI-9361
192.168.1.1
Rack 2
192.168.1.2
Slot0
NI-9149
192.168.1.2
Slot1
NI-9361
192.168.1.2
Slot2
NI-9361
192.168.1.2
Slot3
NI-9425
192.168.1.2
Slot4
NI-9425
192.168.1.2
Slot5
NI-9476
192.168.1.2
Our Architecture is to communicate the IO with Kepware KEPServerEX 6 via Modbus TCP. In the older IO we could do this via MAX once configured we can already assign address, however now we have added the IO via LabView (image below) but can’t seem to get it on KEPWARE over MODBUS TCP.
New setup MAX
New setup LABView
Clarifications:
  1. Is there anything else required for us to configure?
  2. Do we need FPGA or all can work on Scan Interface? As for NI9361 would indicate not supported in Scan Interface (image below)
  1. Is there a Modbus Master or Slave (server or client) built into the NI 9149?
(1,512 Views)
Hello Haizam
Considering on the message below about NI-9361 unsupported scan interface, yes, you should have NI LabVIEW FPGA interface programming mode to develop you project.
For the question "Is there a Modbus Master or Slave (server or client) built into the NI 9149?" try to go through this article to find appropriate information.
Regards)
(1,189 Views)
