Digital I/O
NI 9234 and Accelerometer PCB 320C18
Hi, i have the NI 9234 which i used under MATLAB and it works. I connect to the NI 9234 the PCB 320C18 Accelerometer. I receive data from the acceleromter and the NI 9234. My Question is:
what is the dimension from the data is it [g] or [m/s^2]?
Thanks for the support
(5,688 Views)
Hi there,
How you proceed to collect your data (using DAQmx)? Are these data the sames as in Matlab?
http://www.pcb.com/Products.aspx?m=320C18
My guess is that you receive them in mV if you configure it with DAQmx and a Analogue Input task 🙂
Certified LabVIEW Architect (CLA)
(5,638 Views)
