Digital I/O
NI 9237 Input
I am trying to understand if I can connect a 6-axis force sensor(full bridge) , composed of 6 wheatstone bridges with a single output cable, to the component NI 9237 present in my CompacRio configuration or if I can just convert the signal and use a simple current analog input module like the NI 9208. Are there any advantages in using a bridge adapted module?
(4,597 Views)
You can connect up to 4 bridges to the 9237, for further information consult the link below:
https://www.ni.com/docs/en-US/bundle/ni-9237-getting-started/page/overview.html
Regarding the Benefits of the NI 9237 for Bridge-Based Sensors there is a white paper explaining it much better than I could do:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YRg7CAG&l=en-US
Jovan N. - Application Engineering
(4,537 Views)
