Digital I/O
NI 9401, delay in sending output signal in different channels
I was messing around with a 9401 using LabVIEW's built in digital - continuous output example vi. I noticed that for every channel there is a delay from when the vi is run and the signal actually being sent. On channel 0 there's no delay but on channel 1 there's a delay equal to the pulse width and on channel 2 the delay is twice the pulse width, for channel 3, 3 times ect.
Is this something built into the 9401, or is there something in code doing this that I missed? I plan on using 1 second pulses and having several second delays on some channels is not preferable.
(1,715 Views)
Accepted by topic author Joepeep
That's because the output array is written that way. The output order is:
  1. 1: 00000001
  2. 2: 00000010
  3. 4: 00000100
  4. 8: 00001000
and so on... If you want all the channel to output  at the same time, try 255 as that would be 11111111.
(1,685 Views)
Thanks! This fixes the delay issue but now I can only get constant output although that's what I want in this case.
(1,661 Views)
