Digital I/O
NI 9401 with cRIO 9073
DearEngineers,
I am using NI 9401 DIO card with cRIO 9073.
I should use 1 channel and generate the frame of 96 bits. The bits will be user configurable. How doi do it. If i get answer to this i shall be able replicat the same with other 3 channels. So my Agenda is to have the frame format generated using 4 independent channels.. Please help me out with the solution and the help shall be greately appreciated
Baud rate of the signal shall be 9.6kbps.
Bhargav
(4,968 Views)
Dear All,
Can any body help me with how do i find the CRC for 8 byte Data. Along with Manchester Coding for 8 byte Data
(4,940 Views)
