Digital I/O
NI 9403 I/O Configuration
Goodmorning,
I have a problem configuring the channels, I want configure some channels as input and other as output.
My HW configuration is the following:
  • 1 NI cDAQ-9178
  • 3 NI 9403
  • 4 NI 9205
  • 1 NI 9264
I'm working at my SW in VB.NET (.NET Framework 3.5)
I have searched on the Help and on the web but I'm not able to find nothing written about the possibility how to set  the digital channels on NI9403
I want configure my DIO channels as 24 output channles and 8 input channels (precisely the last height channels, from the DIO24 to DIO31).
Someone can help me to solve this problem?
Thanks in advance at all for the cooperation.
Davide.
(4,575 Views)
Have a look at the examples for Digital IO:
C:\Dokumente und Einstellungen\All Users\Dokumente\National Instruments\NI-DAQ\Examples\DotNET3.5\Digital
(If you do not have these examples you have to re-install NI-DAQmx and select .NET 3.5 examples within the installation wizzard.)
Have a look how to create a task and channels (or use examples above):
http://zone.ni.com/devzone/cda/tut/p/id/5409
You have to use
myTask.DOChannels.CreateChannel(...);
myTask.DIChannels.CreateChannel(...);
(4,544 Views)
