Digital I/O
NI 9403 Pinout & Connections
I am developing a test PCB to use with the NI 9403  5VTTL Digital I/O:
I am controlling a bank of 32 MOSFETs (N-Channel) to conduct open circuit testing on the DUTs. I noticed that pin 19 on the NI 9403 connector is marked RSVD. A quick search of the forums lead me to this post:
http://forums.ni.com/t5/Digital-I-O/In-the-NI-9403-pinout-what-is-RSVD-on-pin-19-mean/td-p/792905
It seems this pin is "reserved" but I can find no documentation on it in the NI 9403 datasheet. Does anyone know if I need to tie this pin to anything (ie. GND) on my PCB, or leave it floating?
Thanks!
(4,035 Views)
I would just leave it unconnected.  It is reserved for NI to do whatever they want with it.  And I don't think you just want to ground an output (if that is what NI decides to do with it).
(4,028 Views)
