Digital I/O
NI 9472 is not generating a pulse train correctly with 500Hz
I have a NI-9472 inserted in the slot 6 of a cDAQ-9189 chassi. I am trying to generate a PWM, however I am facing some difficulties. When in frequencies around 150 Hz, I obtain correctly the pulse train, but as I increase the frequency it looks like the signal takes longer to go to low level.
I tryed to get the waveform with an oscilloscope connected directly to the output of the NI-9472, and the attached images show the situation I have described.
I looked at the manuals but couldn't find any clue. I think the module should be able to generate higher frequencies but I couldn't do it. Does anyone had this issue before or what should be done?
Thanks in advance.
Best regards.
(2,979 Views)
How are you generating the PWM Signals? Can you post your code for analyzing?
The following whitepaper is a good example how to create a PWM signal using the DAQmx Counter Output.
Pulse Width Modulation (PWM) Using NI-DAQmx and LabVIEW
Lincoln
(2,930 Views)
My guess is this has been resolved already, but I just ran into a similar issue. The issue is likely the a result of not driving any load with your signal output. Put a 1kohm across your signal and that should discharge any capacitance in the circuit.
(1,848 Views)
