Digital I/O
NI 9482 Relay Module life expectancy
I cannot find clear information about the maximum relay cycle of the NI 9482 Module.
The following is written in the user manual:
Life expectancy
Mechanical (no load).................. 20,000,000 operations
Electrical (connecting to load) ... 100,000 operations
MTBF ............................................... Contact NI for Bellcore MTBF or MIL-HDBK-217F specifications
What does it mean "no load"? What is the interest of using a relay if nothing is connected to it?
(1,692 Views)
Hi!
The reason we specify the life expectancy without load is because it can vary a lot and we can't test the module for every load possible.
I hope it helps you to understand. To get a more detailed explanation, please follow this link: http://zone.ni.com/reference/en-XX/help/375472H-01/switch/relay_life/
Clement
(1,659 Views)
Thank you Clément for your reply. In our application, the current through the relay will be 10µA, so we will consider 2 000 000 cyles of lifetime.
Best regards.
(1,604 Views)
