Digital I/O
NI-DAQ (legacy) for DIO 96 on a Mac
I am running Labview 7.1 on a Mac OS 10.4 with a PCI DIO 96 board.  Can I use NI-DAQ (legacy) rather than NI_DAQmx Base with this configuration?  I'm trying to get some vis I wrote several years ago up on this system ASAP and haven't had much of a chance to get in the DAQmx Base.
Dave
(3,182 Views)
Hi Dave,
The only DAQ driver that works under Mac OS 10.4 is the NI-DAQmx Base driver. The Traditional NI-DAQ (legacy) driver versions 6.6.1 and 4.9.4 only work under Mac OS 9 and previous. If you are having trouble getting things setup under NI-DAQmx Base the getting started guide, Getting Started with NI-DAQmx Base for Linux and Mac OS X Users, steps you through setting up the drivers, making sure your device is recognized, and getting to the example programs. Let me know if you have any questions.
Nathan
NI Chief Hardware Engineer
(3,171 Views)
